Old 11-15-2014, 06:27 PM   #1
Reebuck1
Reebuck1
3.4 motor swap into 1998 boxster
Anyone have any thoughts??
DME is 5.2.2 from the 2.5 Boxster
Intake and throttle body is from the 996 Carrera
Air filter box is from a 987 but converted to fit in the 986
3 1/2 inch silicon piping runs from air filter to throttle body
MAF is stock from the 996 with the 3 inch 987 tub that holds the 996 MAF
MAF is located approximately 6 inches from the throttle body opening.
oxygen sensors are the stock 2.5 oxygen sensors
Finally got the motor in the car and started it up today....major mile stone.
I had my DME re-flashed with a ROW flash. Am running CAT by pass pipes with no muffler as of yet.
Put the boxster 2.5 pre-CAT oxygen sensors on the by-pass pipes.
No seats in car yet.
Motor started right up...at idle ...NO FAULTS !!!
blipped the throttle a few times and got the following FAULT CODES:
P1319
P1318
P1317
P0300
P0306
P0305
P0304
P0150
I am only guessing......... I have a bad Oxygen sensor in bank 2 (4,5,6)
Cleared faults...and again at idle, it caused no fault code. gave it some revs. and same codes as above showed up.
Any thoughts?
Pictures and writ-up to follow.
Thanks, Bob
Reebuck1 is offline   Reply With Quote
