Hi Steve,
Thank you for taking the time to reply.
I am fairly sure that diagram shows the microswitch on the outside door handle. That switch seems to work fine as if i lift the door handle from outside the car then the window drops.
The problem is when I am sitting in the car and pull the door handle to get out, the window doesnt drop and it makes a horrible noise as the window hits off the roof :-(
