Probably not a lot of people that have installed both. I will tell you (as you have read) that a suspension upgrade, if you are racing or AXing, is transformational. I personally wouldn't spend the money just for a lower look - lowering springs are a LOT cheaper and will do the trick.
I have the PSS9's, and wow - whole new car on the track.
Mantis 2.0L Deep Sump, de-snorkeled, Bilstein PSS9 Coil-Overs, Rennline lug studs, and auto crossed regularly.
