Old 11-11-2014, 09:40 AM   #8
JayG
On the slippery slope
JayG's Avatar
UPDATE....
The Home Depot spring was way to weak and IMHO did not give enough push
From what I have read, the factory spring is around 52 lbs/inch spring rate and the Home Depot one is ~25 lb/in.
I got a used replacement one from itsnotanova (Search for him on this forum) for $15 shipped and it is perfect! I did find a new spring that was close, ~40 lb/in, but decided to go with the factory spring instead
Much better feel with the stronger spring.
FYI, you do not need the spring at all if you prefer a "heavier" clutch
Also , the circlip broke that holds keeps the bolt (#8 in diagram) from sliding out. I just replaced it with an E clip, works perfectly
Thanks again Woody
2004 996 Targa Tip
Instructor - San Diego region
