					Originally Posted by Jake Raby  This is a very poor method of securing the IMS during the procedures.
 Have you pulled the other two tensioners completely from the engine? Were you on TDC when you began the procedure?
I am certainly not disagreeing with you there - should have at least ordered proper set screws.  I followed the Pelican Parts guide that uses set screws and doesn't call for starting from TDC.
I was not on TDC when I began the procedure.  I initially removed both tensioners completely, though they are now partly screwed in.
					Originally Posted by Jake Raby  How did you break the flange? |
Flange is partly broken because I cut off the nut that was attached to it outside of the engine case.  I was not able to rotate the nut with respect to the flange and eventually cut it off because the flathead end of the flange was stripped.
