Old 11-10-2014, 04:50 PM   #10
gonzojive
This is a very poor method of securing the IMS during the procedures.
Have you pulled the other two tensioners completely from the engine? Were you on TDC when you began the procedure?
I am certainly not disagreeing with you there - should have at least ordered proper set screws. I followed the Pelican Parts guide that uses set screws and doesn't call for starting from TDC.
I was not on TDC when I began the procedure. I initially removed both tensioners completely, though they are now partly screwed in.
How did you break the flange?
Flange is partly broken because I cut off the nut that was attached to it outside of the engine case. I was not able to rotate the nut with respect to the flange and eventually cut it off because the flathead end of the flange was stripped.
gonzojive is offline   Reply With Quote
