From the pelican website:
If you own a 2000 Boxster or 2000 Boxster S, then you need to make sure that you have the proper sensor installed. Much confusion lies in the fact that most people don't know if their car has been updated by Porsche or not. If the old sensor that you removed is 996.606.124.00, then you need to replace it with the same part number (or have Porsche update your DME software to accommodate the newer style sensor: see Technical Service Bulletin 1/00 2445 Air Flow Sensor -- dated 4-18-00). If the old sensor you're removing ends in 125.00 or 125.01, then replace it with 986.606.125.01 (the latest version available).
Previous 2 seaters:
1975 Triumph TR7
1979 Fiat X19
1977 Lotus Esprit
Honey it's an investment!
