Old 11-08-2014, 12:13 AM   #1
wengers670
Post F/S Outboards Engines Honda 135 HP 4-Stroke outboard
We offer best services and distributors of boat engines,all our outboard Engine are
brand new original , working perfect in good conditions .Warranty is the best .
this is transferable, non-declining warranty is the same on the last day as it is on the first
. Right now we have a promo offer going on and if you order more than 2 outboard
engines you get more discount.
The item must be returned unused in its original box, with all paperwork, parts and
accessories.
Shipping
We ship using USPS,UPS,DHL or FedEx
We ship within 3 5 business day from receipt of payment.
We do not change your shipping address by email. Please make sure your address is
correct before checking out and making payment.on our website
We do ship to APO, FPO, Post Office box addresses.
We do ship to worldwide its free
Support
With any question regarding our items please do not hesitate to message us and we will
be happy to answer and assist you.
Contact us through the following Email below
Contact Email Address: engmotboards99@hotmail.com
Skype: edgeacessltd
Specification for Honda 135 HP 4-Stroke outboard
Engine
BF135 BF150
Type 4-Stroke DOHC 4 Cylinder/16 Valves 4-Stroke DOHC 4 Cylinder/16 Valves
Displacement 2,354 cc (144 cubic inches) 2,354 cc (144 cubic inches)
Bore & Stroke 87 mm x 99 mm (3.4 x 3.9 inches) 87 mm x 99 mm (3.4 x 3.9
inches)
Full Throttle RPM Range 5,000-6,000 RPM 5,000-6,000 RPM
Rated Power 135 HP @ 5,500 RPM 150 HP @ 5,500 RPM
Cooling System Water Cooled Water Cooled
Fuel Delivery Programmed Fuel Injection Programmed Fuel Injection
Ignition System MicroComputer Programmed MicroComputer Programmed
Starting System Electric Electric
Exhaust Through Hub Through Hub
Lubrication Wet Sump Wet Sump
Trim Range -4° to +16° -4° to +16°
Tilt Range 72° 72°
Drive
BF135 BF150
Gear Ratio 2.14:1 2.14:1
Gear Shift F-N-R F-N-R
Alternator (Electric Start) 51 Amp 51 Amp
Battery Charging Power 30 Amp (1000 RPM), 40 Amp (2000+ RPM) 30
Propeller Optional Optional
Power Tilt NA NA
Power Trim & Tilt Standard Standard
Gas Assisted Tilt NA NA
Oil Pressure Alert Standard Standard
Temperature Alert Standard Standard
Rev-Limiter Standard Standard
Speedometer Pickup Standard Standard
Dimensions
BF135 BF150
Overall Width 580 mm/22.8 inches 580 mm/22.8 inches
Transom Height
BF135 BF150
L Type 508 mm/20 inches 508 mm/20 inches
X Type 635 mm/25 inches 635 mm/25 inches
Dry Weight
BF135 BF150
L-Type 217 kg/478 lbs. 217 kg/478 lbs.
X-Type 220 kg/485 lbs. 220 kg/485 lbs.
Availale products!!!!
Honda 105 HP 4-Stroke outboard Motor $5,000 usd
Honda 150 HP 4-Stroke outboard Motor $5,500 usd
Honda 225 HP 4-Stroke outboard Motor $6,000 usd
Honda 135 HP 4-Stroke outboard Motor $6,500 usd
Yamaha 60 HP 4 Stroke Outboard Motor Engine $3,500 usd
Yamaha 30 HP 4 Stroke Outboard Motor Engine $2,000 usd
Yamaha 40 HP 4 Stroke Outboard Motor Engine $2,800 usd
Yamaha 75 HP 4-Stroke Outboard Motor Engine $3,000 usd
Yamaha 115hp, F115LA 4-stroke, 4-cylinder, 20" Shaft -Electric Start - Remote Steering
$4,500 usd
Yamaha 350hp, F350XCA 5.3L V8 Four Stroke, 25" Shaft -Electric Start - Remote Steering
$5,200 usd
Mercury 90HP Four Stroke Outboard Motor $3,300 usd
Mercury Four Stroke 100 HP EFI Outboard Engine $3,500usd
2012 Mercury Pro FourStroke 250 - 300 HP Outboard Motor $4,000 usd
2012 Mercury OptiMax 250HP Sport XS $4,000 usd
Mercury 125 HP OptiMax $3,400 usd
Mercury 150 HP OptiMax $3,000 usd
And many more Outboards Engines Models are available in STOCK at this special price.If
you are interested please reply Us via mail.
Shipping :Shipment is through FedEx , DHL , UPS = System and duration.
Skype: edgeacessltd
wengers670 is offline   Reply With Quote
