Old 11-06-2014, 04:45 PM   #74
Jamesp
Beginner
Jamesp's Avatar
Originally Posted by flaps10 View Post
Well apparently they didn't read the instructions, or didn't use enough. cough.
I didn't have time for a pic this morning as I suited up for the ride in, but I did look at the crankcase side of water pump housing. It is slightly discolored from the coolant but it is 100% "as cast" and doesn't have a mark on it.
That's good news. Parts are expensive, but you are in a position to turn back the clock on the parts in your engine that tend to wear. My rings had 120K on them, and while clearly worn (about 1/3 gone), they sealed fine, so I kept the $1200 (wow! price rings for anything else) but replaced the really worn parts like the bearings which were down to the steel backing. Check out Gaudin Porsche for good deals, but watch out for shipping. Also, if you are going to replace your IMS bearing do a little research on bearings in general which helps in the decision on what to put back in. I liked the Pelican bolt and seal, but not the bearing due to the seal. Keep up the great work and thanks for the post!
2003 S manual
