Old 11-04-2014, 03:31 AM   #2
JFP in PA
Originally Posted by carlosnolasco View Post
Could somebody post a picture of the tool or machine to do a complete transmission flush for the Boxster? How much could cost? how could I check if I am low on transmission fluid?
I assume you are referring to the Tiptronic transmission, and if you are, the answer is simple: It does not exist.
The reason for this is that most trans flush units attach to the trans via the trans cooler lines running to the transmission oil cooler, and because the Tip has a water to oil cooler attached directly to the transmission, there are no external oil lines to hook the machine to.
To service the Tip, you need to drain the pan and replace the filter. This will only get about 1/2 the old fluid out, but it is the best you can do. Do a search, procedure has been written up. It will also show you how to adjust the fluid level correctly.
