Old 11-03-2014, 06:30 AM   #1
Topless
Track rat
Topless's Avatar
The Acton pocket reader is my preferred diagnostic tool. Only the info I can use and nothing beyond my backyard wrench status that will cause me to overthink a problem and change a bunch of unnecessary parts. It is always in my car.
That said, I think it is unlikely that a bad O2 sensor is causing your code. You can pull it and do a visual inspection but P0430 usually means a weak/failing/sooted cat. If the sensor is failing you will usually get an "aging sensor" code instead.
Good luck!
