Old 11-02-2014, 06:57 PM   #1
Daniel R
ABS Wiring Harness Replacement
Hi
At some point I had a short in the front left ABS wiring harness where it connects to the sensor. I finally got around to buying replacement sensors, assuming this was the problem, although I have since found that it is the harness that is damaged.
Does anyone have a part number for this front left harness repair kit? It is probably best to conform this before spending more money unnecessarily. I have only found the part described for a 996, which probably means it is a shared part but none of the seller's websites confirm that it will fit a 986 Boxster S.
Thanks in advance
Daniel
Daniel R is offline   Reply With Quote
