Old 11-01-2014, 07:19 PM   #12
patssle
This is so LN can ensure that your old bearing was not failing, because if it was, your retrofit bearing will also likely fail
How does the original bearing failing impact a new bearing? And what's an expected life for a replacement bearing if the original is failing...at least long enough to make the replacement worth it?
