Old 10-31-2014, 05:52 AM   #5
linderpat
linderpat's Avatar
I have done this project and it is not bad. You do have to remove the door panel, and work your way up into the inside where the handle is. Be absolutely certain to use the correct tools - for instance the star bit to remove the lock plate on the door jamb. Otherwise you will strip the bolt. Also, be sure to deactivate the battery before removing the air bag (if you have it on the inside of your door panel). The 101 Project book and other tutorials on these forum tell you exactly how to do all of these things.
Ed
Pittsburgh, PA
78 5 spd 928 Blumaxx (in Hemmings S & E issue #100)
85 928S garnet red stock daily driver
06 Mustang GT Legend Lime and modified to go even faster
linderpat is offline   Reply With Quote
