Old 10-29-2014, 01:10 PM   #1
cincyjohn986S
Door / window problem.
Well... I just picked my car up from the shop after they replaced two of my CV boots.
When I picked it up, the guy at the shop asked me if I had been having trouble with my window. I said NO! And then he showed me...
The window goes down when you pull the door handle, and goes back up even with the door open. Also, the dome light doesn't come on when the door is open. It works fine when the passenger door is open. You can't close the door from the outside, because it hit' she convertible top. The only way to get around it is to close the door with the window open, then close the window by holding the key in the lock position from the outside.
The mechanic said the only way to access the door switch is to dis-assemble the whole door, and window.
I told them I'll deal with it later.
Anyway, my question is, does anyone know where the door switch that tells the car the door is ajar is? I can't find a listing for a "door switch" anywhere. All I can find is "window regulator", and "door lock mechanism".
Anyone else have this problem?
Thanks.
cincyjohn986S is offline   Reply With Quote
