Thread: Used Litronics
Old 10-28-2014, 07:55 PM   #1
KevinH1990
KevinH1990's Avatar
Used Litronics
I have an offer in on a pair of used litronics. I have done some research, but I'm a bit unsure of how to proceed. Here are my questions:
1. If I install them without the control module and wiring harness that comes with the retrofit kit, will they work? It seems that based on my research, the low beams won't swivel up to assist the high beams.
2. If one of the projectors is loose, can it be repaired? I haven't found anyone who says they can, but it appears you can take them apart with a little heat, so if the price is right I'm wondering if it is worth a try.
Thanks in advance for any tips or suggestions.
