Old 10-23-2014, 05:38 PM   #2
jaykay
jaykay's Avatar
Angry
Okay I let someone else work on my car as I had no garage access....this is what got:
Along with a stripped console bolt, missed electrical connection, and scratches on the inside of my plastic window....I even had pre stripped the interior....anyway after two weeks I had to pull my car out of there
The shift quality is terrible compared to what I had set up. I can barely get into reverse....so pull the engine cover and found this cable lashed against the plenum
One cable is way too loose and the other is so tight to the intake plenum that I don't need bolts to hold it in the head....ahhh have they reversed the cables? What routing did everyone use here?
I would imagine that one run under the plenum would make sense..
I am afraid to drive it like it is
986 00S
