Old 10-17-2014, 10:51 PM   #2
Cebu
I'm going to try this tomorrow morning. I did a reset prior and the CEL went away. It came back on I'm guessing after 150 miles of driving. Same error. Thank you for your feedback it's much appreciated!
Clear the codes and see what comes back after a day or so.
When the car is warmed up, using the Durametric, go to actual values and click on O2 sensor voltage before and after cat 2. I f you get a more ore less flat line and a wavy line, the cat is good. If both lines are wavy, the cat may be bad. I picked up a used cat from European Parts Depot on eBay for $120. It came with two O2 sensors. The problem is now gone and as a bonus, it also cleared up the SAI code I was getting! I don't know why this is but I'm not complaining!
Cebu is offline   Reply With Quote
