Old 10-15-2014, 11:47 AM   #6
Topless
Track rat
Topless's Avatar
[QUOTE=whitecliffs;421750]I already have a pedro techno torque fitted
Still sounds like a fouled MAF. I had a similar problem with a flat spot and no error codes yet. I cleaned the MAF and it improved for a while but came back over time with codes. Replacing the MAF was the cure.
The MAF is only a month old and a genuine Bosch one, if the MAF was faulty wouldn't it show up in other areas and not just at 5400rpm because once passed 5600 it pull clean and hard again everytime
If it is brand new Bosch and clean it is probably ok. A flat spot in the rpm range while running fine everywhere else is a common symptom of a failing MAF. It rarely affects the entire upper range unless it is completely fouled.
