					Originally Posted by  JAAY
				ipd plenum will fix your flatspot
I already have a pedro techno torque fitted
[QUOTE=Topless;421741]Still sounds like a fouled MAF.  I had a similar problem with a flat spot and no error codes yet.  I cleaned the MAF and it improved for a while but came back over time  with codes.  Replacing the MAF was the cure.
The MAF is only a month old and a genuine Bosch one, if the MAF was faulty wouldn't it show up in other areas and not just at 5400rpm because once passed 5600 it pull clean and hard again everytime
