Old 10-14-2014, 03:35 PM   #1
BoxsterSteve
still plays with cars...
BoxsterSteve's Avatar
Originally Posted by todds99 View Post
Is the engine and 6 speed a direct bolt up?He only had 50,000 on the car before he wrecked the front passenger corner.I don't need problems..
The engine and transmission will bolt up, but you'll probably end up with 1 forward gear and 6 in reverse... the transmission is spun 180 degrees in the 996.
I've read that the main difference in the G86-20 transmission between 986 & 996 applications is the ring & pinion are installed on opposite sides of the transmission.
Best to just swap over the engine and stay with your 5 speed, or locate a Boxster 6 speed and use that.
Six speed 2000 Boxster S
