Old 10-14-2014, 10:16 AM   #3
seningen
seningen's Avatar
Piston pin height is the simplest term. When you are "stroking" a engine for max swept area volume & thus max displacement you install a crankshaft with longer "throws". Porsche did this in 2002 with the new 3.6L engine. To offset the additional length of the crank stroke the 3.6L has shorter rods & revised pin height pistons.
In the OP's case the pin height will be off & the piston valve pockets & dome will be a different design. This is one of the reasons LN designed the new pistons for this application.
deleted -- had my logic backwards
seningen is offline   Reply With Quote
