Old 10-10-2014, 08:01 PM   #11
dghii
Nice score!
The top and frame R/R is not tough at all. Remember that there are two phillips screws on each side along with the three bolts. The screws might be hard to see if you don't know to look for them.
When installing, get the bolts started, then do the screws.
This is also a great time to replace the plastic rod ends if you still have the originals.
Also a great time (while top/frame is off) to remove your drive cables from the top's motor and inspect for fraying. The cables are easily removed and re installed without worry of needing to realign anything.
