Old 10-08-2014, 09:06 PM   #2
Coaster
Coaster's Avatar
Originally Posted by Ebell914 View Post
What tires did you put in back? Are they up to spec? If the sidewall is not as stiff as the fronts, it may cause this (speed rating same?).
Went with Michelin Pilots A/S 3 in the back. Pilot SS in the front. I believe they are up to spec.
2003 S, 6 Speed, PCM, PSM, Bose, Litronics with washers, on its' second LN IMSB, comfort top, UDP, 987 engine mount, 997 RMS, Koni Sport Shocks, H&R springs, Techno brace, comfort blinkers, nin8six windscreen, particlewave light up cubby
Coaster is offline   Reply With Quote
