I can't imagine that "tilted back and low" would be any kind of advice for driving. Well, unless you've got limo tint and are cruising in my neighborhood...
Provided that your vehicle has enough adjustment, you should try to find a position that allows you to perform all necessary actions without shifting your body. If you find that you are constantly "twisted" or leaning to the right when shifting - then you're not close enough. Not only is that bad "form", but it can be hard on your body after hours of driving.
At 5'9", I would think you would need the seat up several pumps (at least). High enough to feel comfortable but without feeling like you have to look under the top of the windshield. The seat should be adjusted forward until you can comfortably shift and fully activate the pedals. The steering wheel should then be adjusted (forward/back & up/down) to give you a slightly relaxed grip (you shouldn't feel like you have to reach or lean forward). If it seems that getting the proper distance for pedals brings you too close even after adjusting the steering wheel - then adjust the seat backs.
Well, that's how I do it anyway....
'06 Cayenne Turbo S, Beige Metallic/Tan
Ex - '99 Arctic Silver, Red Interior, Silver Top
