Thread: First ticket
Old 10-05-2014, 08:36 PM   #12
cfos
I can't drive after 8 until next month, no hiding of that, however, it does seem I was not clear, I by no means ment that the drivers of these busted up cars or such are less likely to be respectful or anything else, but what I personally have heard is that cops tend to be more lenient based on how much of a threat the vehicle you are In poses to others. A tractor trailer traveling at high speeds is quite a threat to all motorist around, while an accord going the same speed is less threatening to other motorist. Can be the exact same driver or kind of driver between the two cars, in the case I personally had an suv, I would be much more accepting of a ticket in the suv under same conditions and unlawful driving then doing the same in the boxster. However, either way, I am pretty excepting that the law is the law and under no circumstance are you entitled a warning or reduction, however, I would be more expecting of a ticket in the case I was driving an SUV.
Seriously:
http://faculty.washington.edu/heagerty/Courses/b572/public/StrunkWhite.pdf
Your credibility will rise, once you grasp some basics. Also, you use too many qualifiers.
Out of curiosity, what and from whom do you hear things?
2k13 Boxster Amaranth Red/Black
cfos is offline   Reply With Quote
