Old 10-05-2014, 01:06 PM   #5
Timco
I am my own mechanic....
Timco's Avatar
I use a 8000W (12,000 peak) generator and a 10/3 SO cable from outside my detached garage (50' from house) and run that to a 2-pole 40A open breaker. That back-feeds the entire meter base and house panel. The main disconnect MUST be off to not send voltage to the lines or conflict when the power comes back on. Runs AC, range, TV, and everything I could turn on.
Note. A proper transfer switch should be used. Big job to install.
I HAVE, however, used the Box to jump Genny.
'08 VW Touareg T-3 wife's car
