Old 10-04-2014, 04:32 AM   #11
Listerofsmeg
Absolutely spot on, there is zero compression im cylinder 1, 12.5-13bar in all other 5. In other cars that would normally suggest a hole in a piston....damn....
Do the compression test first before replacing anything. I bet you'll find the results interesting...
(lots of smoke + missing/rough running + oil in the exhaust ports = usually not good things)
Listerofsmeg is offline   Reply With Quote
