Old 10-03-2014, 09:25 AM   #2
BYprodriver
BYprodriver's Avatar
This is pretty complicated so I will type even slower than I usually do. 1st install your sump plate extension. While the sump plate is off measure how much the dipstick protrudes from the end of the tube. Now do whatever you want to do with the oil filler/dipstick gizmo. Finish all modifications. Reinsert dipstick in engine mounted tube, if it protrudes lower than before, cut off to the oem length + thickness of the sump spacer you are installing.
