Old 10-03-2014, 06:33 AM   #10
seningen
seningen's Avatar
Originally Posted by redeye280z View Post
I agree that changing all 4 sensors doesn't make any sense. I did rectify the code the sensor was giving but I am still getting code 0410 and 1411. I am assuming that since I did work on the throttle body and the AOS maybe one of the vacuum lines came loose or cracked due to manipulating them. Any tricks for a home mechanic without a smoke machine to check for leaks?
you can try spraying carb cleaner or similar which has alcohol in it. If your idle changes -- there
is a leak where you sprayed.
Caveat -- you are spraying a flammable substance on a combustion engine.
I take no responsibility for anything :-) Although I have successfully done
this on a 928.
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
