if replacing your ignition switch doesnt correct the window issue, its likely your micro switch in that door is become unclipped from its factory mounting point behind the outside door handle or the switch is worn out.
To test the microswitch, while your door is closed, lift the outside door handle and the window should drop automatically (1/4 of and inch give or take) just as/before the door is about to open.
if you dont get that drop, its your micro switch.
