Old 10-01-2014, 04:38 PM   #1
redeye280z
2 fast 4 U
Keep getting CEL need some help
Recently I have replaced my AOS and cleaned my throttle body completely. The two codes that lead me to believe my AOS did not come back so that problem was solved. The only code that was left was P0153 ageing O2 sensor. Last night I replaced the precat sensor on the passenger side. This morning I went to work and all was fine no codes. This evening my CEL came back on and now the codes are P0410 P1411 and P0153. Now I know the 2 first codes have something to do with vacuum but they only appeared since I changed the sensor and also why am I still getting P0153 the sensor is new.
Can a faulty 02 sensor cause theses codes. I am sure I put all the vacuum hoses back where they belong and I can here the air pump working on start up.
Drive it the way it's meant to be driven!
2000 Boxster S
redeye280z is offline   Reply With Quote
