You guys do realise you are talking about two different "fans" - the 2 x cooling / AC fans mounted at the front of the car, and the engine compartment cooling fan mounted just inboard of the R/H side air vent.
The OP first asked about controlling the engine compartment fan, which in my experience only operates for a few minutes in heavy traffic then quickly stops when you get underway and get air circulating around the engine. Its only a small fan with a +/- 100mm blades which really can't do much (apart from making a loud noise) to cool the compartment in stop go traffic or get rid of heat soak after the engine has been restarted after long periods in traffic.
2001 MV Agusta F4.
