If you can solve the DME problem...doubt you can as JFP pointed out....the switch you have shown would not work. It is a toggle switch that is OFF in the middle position-- HOT on one side(push upper side) and HOT on the other side(push lower side) it reverses polarity from the top of the switch to the bottom. If you use this kind of switch it only needs an OFF/ON function not the pole switching capability that this switch has. Hope this helps.
