Old 09-25-2014, 11:46 PM   #1
Steve Tinker
Steve Tinker's Avatar
There is a plastic / rubber membrane sealing around the inner door cavity. If this membrane is damaged or the adhesive has pulled away from the door skin, rainwater can penetrate and fill the cabin.
If you remove the door card you should be able to reseal the membrane with silicon sealer or buy a new one from Porsche.
2001 MV Agusta F4.
