Chris...
Are you referring to Pedro's techno Fix DOF or Flat6's IMS Solution - perhaps its your wording that's confusing me?
I'm assuming that you removed the oil feed line to the bearing which eliminated the "noise" and altered the cam timing - can you explain a little more regarding the type of noise and what changes occurred to the cam timing (deviation?).
2001 MV Agusta F4.
