Old 09-24-2014, 02:31 PM   #6
JFP in PA
Originally Posted by epapp View Post
Well, if that's true, which would be odd that they are wasting CPU time to check for a fan to be on that they did not turn on (avoiding proper coding technique discussion), then you could route your own power to the fan (annoying) and a few diodes later then fan would be under your control without letting the ECU know about it.
Then again, that's all probably a huge waste of time and you should rather implement an engine misting feature which lightly mists the engine to shed more heat
Unfortunately, the DME controls both the coolant fans and the engine bay fan, which is why they are so hard to alter the on/off temperatures. But because they are controlled this way, a Porsche diagnostic tool can test and even activate them at a keystroke, which makes trouble shooting a bit easier.
