Old 09-23-2014, 02:59 PM   #1
JFP in PA
Originally Posted by seningen View Post
A hammer stroke or two to set the tri-square and it usually comes out ok without stripping. Make sure the heads of the bolts are clean -- they can gunk up and
the tri-square doesn't set deep enough.
Note when you reassemble, check the torque specs -- and again
after 100 miles or so -- they can work themselves loose again.
Mike
Or clean both the bolts and the threaded holes with brake cleaner, use a dab of Loctite, and torque to specs. Then they will stay put.
