Old 03-31-2006, 04:52 AM   #2
MNBoxster
Originally Posted by rdancd816
Ironically I got a good scrape on the underside of my front bumper going into my Porsche dealership's driveway! Anyone tackled a fix on a DIY basis? Seems a little extreme for a body shop repair. I'd like to know sandpaper grit and prep tips if any of you have tried this. Thanks!
Hi,
Depending upon how deep the issues are, an epoxy sanded and then painted are your best bet. The advantage of epoxy is that it adheres well, sets quickly, and since it doesn't off-gas it won't shrink once it cures. It can be sanded, then painted. This is how 3M recommends repair using on of their epoxies - see: http://products3.3m.com/catalog/us/en001/auto_marine_aero/automotive_aftermarket/node_GSRBDQRS68be/root_GST1T4S9TCgv/vroot_GSLPLPKL4Xge/gvel_6DTWTJQPBBgl/command_AbcPageHandler/theme_us_aad_3_0
If you have a series of scrapes, I would fill them a little proud with epoxy, then sand them using 1200-2000 grit papaer, followed by OEM touch-up paint carefully applied with a fine detail brish.
Depending upon how much care you use, the rerpair will be permanent and range from hardly noticeable to totally invisible. Hope this helps...
Happy Motoring!... Jim'99
