Old 09-22-2014, 07:38 PM   #11
j911brick
SO here is what have figured out. Its probably a component on the engine. With the DME disconnected the fuse does not blow. SO I hooked up the DME and unplugged the white and black multipin connectors. If either one of the connectors is unplugged the fuse will not blow. Only when they are both connected does the fuse blow.
j911brick is offline   Reply With Quote
