Old 03-31-2006, 04:53 AM   #14
986Jim
I'm just not quite sure how an LS1 would fit. The motor and tras are quite long, I'm wondering how you would fit the rear end assembly in there as well. The drive shaft would be 3" long at best if it would all fit together. The boxster is basically like a FWD motor in the middle of the car, ie no rear end no drive shaft, just motor trans to a set of half shafts right out of the diff located inside the trans like a FWD car.
There really isn't much length to play with, I can see the motor and trans fitting in but the rear end would probablly touch the transmission not even allowing for a drive shaft to be fitted, there just isn't that much room for a long motor/rear end setup like that.
986Jim is offline   Reply With Quote
