Wrench turning began this past Friday. I've got a garage which my woman has agreed to leave me in charge of (guess who owns the rest of the house?). These are just going to be a couple of quick tear down pics with notes of things I learned.
My guide thus far (besides my past experience) has been Wayne's book (101 projects for your pet rock), and also a blog that was produced by another individual in the same situation I'm in. I'll have to post up the link later since I don't have it on this computer.
If Wayne's book has any defect it is only that it forces you to refer to other chapters of the book to perform the tasks. It's not actually a defect at all, as otherwise the book would be five times as thick with a bunch of repetitive tasks.
The above pile was generated at the end of a relaxing day with my car. I forget the exact name of each item but the stiffening pan, suspension supports, rear sway bar, heat shield and exhaust system all ready for clean up and storage.
As a funny aside, when my SO came to check on my progress I pointed at the exhaust system and said "that thing is not going back on this car". She laughed and said "Cute. You know I can totally read your mind". I'd swear I had a straight face. FYI, planning on the Borla exhaust when it comes time.
A quick view of the underside with a
whole lot more space open than when I started.
In this picture the shift linkages are popped loose but the cables have not been removed from the bracket.. Since the photo was taken the large aluminum mount has been removed from the rear of the transaxle, reverse sensor switch is off and tucked away, the clutch slave cylinder has been removed (dammit, I just installed that a couple weeks ago) and the CV joints are off the transaxle.
The engine is currently supported for the pending removal of the transmission. All that remains is to slide my floor jack under it, remove the two transmission mounts (the black sheet metal Y shaped brackets and the isolators at the outboard ends), and the bolts holding the transmission to the engine.
I've already got the 10mm "triple square" drive for the odd bolts. In case anyone falls for the same thing I did, triple square =/= Torx.
One more comment on this post, and that is that you can see in this pic that my habit has always been to immediately put all hardware back where it came from. That dispenses with putting things in baggies and labeling things. It also forces me to clean up all the hardware after removal of each individual part. This method has served me well for many, many years.
