Old 09-21-2014, 05:25 PM   #5
BFeller
JFP in PA would know, he's probably done a few. A bright light also helps. I had to follow the wire into the crevice were the sensor is located with my hand. I did not do it on a TIP. It took almost every extension in the tool box. Then to make sure I did not strip the torx head on he bolt, I leaned into socket and hand my finger on the bolt head to be sure Everything was in place. I put the long 6 inch extension onto the torx bit, then a couple of three inch ones going to the rachet wrench. Once you crack the torque on the bolt it a breeze. Just dont drop the bolt, its tiny.
