Replaced the fuel and air filter, pulled the throttle body and let it soak in carb cleaner overnight, cleaned all the plenum boots, tighten all the clamps, cleaned all the sensors, and put in injector cleaner. Turned it over and it struggled a little bit then it kicked on there was a distinct pop sound and then she started running fine. My idle held steady at 900 rpms no more weird smell. I did notice after the fan kicked off I can hear a slight hissing noise I noticed it before but never payed much attention (especially since I don't take the engine cover off often and it's not noticeable with it on). Anybody know if this is a fairly normal sound or do I have some kind of vacuum leak?
