"Engine
Any 283-350 Chevy small block V-8 will work, but the “F body” LT-1 is arguably the best motor for this application. These Chevy V-8 engines generally produce 250 horsepower and above, with streetable performance levels approaching 500 horsepower. The advantage of choosing the V-8 over the V-6 is a smoother running engine with less vibration and greater power. To further the advantages, the LT-1's out of a Camaro or Firebird actually have a compact enough fuel injection system and serpentine belt assembly that they fit under the stock hood without the use of a hood scoop. The installation of a V-8 engine results in some additional weight to the front of the vehicle. To compensate for the added weight, we recommend the use of heavier springs: 250 lbs. for the V-8.
Weight Distribution
Contrary to popular opinion, the superb handling characteristics of the 944 are not decreased by the addition of the V-8 powerplant. In normally aspirated versions of the 944, the weight distribution changes less than two percent. In the turbo cars, the change is less than 1.5 percent. A typical characteristic of a stock 944 is a slight "push" or understeer during acceleration. We have found that with the added weight of the V-8, the "push" condition actually diminishes. Furthermore, the more manageable torque and predictable horsepower allows the driver to easily transfer weight from front to rear allowing for increased car control. Quite simply it is much more fun to drive a converted 944."
Rich Belloff
