Could you explain what what a OBDII code reader or a multimeter is? Also, what does it actually mean that the engine is turning over? I can turn the key all they way and the car is trying, but just can't get there. I thought it might still be the battery so i plugged the battery charger and left it charging. How long should it take with a 2 amp charger? Also, the engine lgight isn't flashing, according to the manual i think that is somthing different, it is just on. How much would it cost to fix the starter if that is it? Thanks again
