Old 09-14-2014, 10:36 AM   #23
sneakyfe
Also to consider with a permanent ipad install is the wear and tear of daily vibrations from your daily commute. Remember, the iPad was not designed to absorb hard bumps and it will affect your device overtime. So if you're doing a permanent install, perhaps you can add a small foam just to protect the device.
sneakyfe is offline   Reply With Quote
