					Originally Posted by  thstone
				Another way to keep the spoiler up is to raise it manually and then use a PIWIS or Durametric Pro (not the Enthusiast version) to disable the spoiler operation. This should keep it in the up position and you won't get a dash light. But if you ever want to revert back to normal operation, you'll have to enable the spoiler using a PIWIS or Durametric Pro again.
This sounds like the best way to go. In reality, I probably should have one already for the various other uses. Can you recommend a good one that I can buy on eBay or Amazon? Or do I need some fancy-pants gear from the dealership? I have heard of people using a PIWIS cable and an old laptop and having very good results. What do you use?
www.appleneworleans.com
