Old 09-07-2014, 11:51 AM   #19
peterbrown77
Another pleasant hour of my Sunday dealing with Porsche "engineering" (if it can be called that).
Replaced the coolant level sensor with new, plugged it in, and drumroll ----- the light still flashes. So, if it's unplugged it doesn't flash. Which it currently is. I'm not going to get into the rank stupidity that has me remove 2 pieces of carpet and then loosen the entire tank to get the sensor out because they thought it would be a grand idea to position the sensor directly above one of the body seams so you can't drop it out without a written consent decree.
I guess it has to be the float? I can see that it is at the top of it's travel when it reaches a push-on retaining clip. Maybe I should somehow push the clip farther down the float's spindle?
2002 Boxster S, Arctic Silver, 18" Turbo Wheels, 6-speed
peterbrown77 is offline   Reply With Quote
