Old 09-06-2014, 10:50 AM   #143
Shehadehd
Shehadehd's Avatar
Originally Posted by Wilson01S View Post
Well I finished my install and I think it came out great! I love it! I was able to score a 32gb iPad mini with Verizon lte for a steal on CL. I am nervous of battery drain if the car sits for a week and the iPad is charging the whole time, but I guess it's a low amp draw. Also does anyone know how to remove the pins from the Becker harness? I accidentally cut a wire close to a pin on the iPod harness on the sharp metal. Need to remove pin and repair.
Finally there was a wire with a female spade connector that was ok the back side of the cdr220 it's paired in the same harness as the variable wipers. What does this do? I didn't reconnect because it wouldn't reach. Would this have anything to do with my Becker seemingly losing it's display backlight?
If you tapped into the 4-pin molex for the optional phone then the iPad will stop charging when the car turns off. I would recommend making sure it charges off a switched 12v line
If you are interested in a Comfort-Top module, please visit:
https://www.enhancedautomods.com/shop/comfort-top
Shehadehd is offline   Reply With Quote
